Flathead Power BT Cylinders?
MarkBranst
Post Wed May 20, 2009 11:42 am
Any word out there on when Flathead Power BT flathead cylinders are going to become available?
Mark
woody
Post Wed May 20, 2009 7:29 pm
Re: Flathead Power BT Cylinders?
I second the question.
Post Thu May 21, 2009 6:01 am
Give them a call Fellas. :wink:
woody
Post Thu May 21, 2009 7:06 pm
I'm sure that they watch this, so isn't that what we just did? How about it, S&S. Are you listening?
CharlieHadayia
Post Fri May 22, 2009 8:51 am
Hi Guys,
Here is where we are with the BT Flatty cylinders: Working on the tooling tweaks for the ports and are shorting for a Davenport release date. They will have valves, guides and spring pack as part of the cylinders. They will be avalible with stock intake nipples or WR intake nipples and the WR manifold will be avalible at that time also. The springs will take you to (.650") vs. stock .420".
Charlie Hadayia
S&S Cycle Inc
608-627-0292
MarkBranst
Post Fri May 22, 2009 10:46 am
Thanks Charlie.
woody
Post Fri May 22, 2009 7:04 pm
Thanks for the info, Charlie.
Post Fri May 22, 2009 10:06 pm
Charlie,
How about info on something really important, Sport Scout Square base cylinders.
Post Sat May 23, 2009 3:29 pm
Dusty-Dave wrote:Charlie,
How many sets do you think they could sell?
Post Sat May 23, 2009 5:12 pm
If you're still doing the tooling, I strongly suggest that the deck height be shortened slightly. All factory engines are too loose regardless of gasket thickness, and most aftermarket pistons have smaller compression distances than the original.
This is a major contributor to knocking - excessive quench clearance.
Taking off roughly .030" will be safe in all cases IMHO, and be very helpful since tightening up this distance afterward is very complex and expensive.
redromad
Post Mon May 25, 2009 9:29 pm
Can anyone tell me what a Davenport release date is? Thanks from a rookie
Red
Post Tue May 26, 2009 6:14 am
Red,
Davenport (Iowa) is the largest AMCA meet of the year and is always the Thursday through Sunday leading up to Labor Day.
woody
Post Wed May 27, 2009 6:48 pm
Since we're asking, how about connecting rods or pistons that work with 8" rods?
redromad
Post Thu May 28, 2009 4:44 pm
That is most excellent. Will these be UL only or VL as well?
Red
Flatskalln
Post Wed Sep 16, 2009 2:54 pm
Heard/seen anything about them BT cylinders yet?
"Only Bikers understand why dogs love to stick their heads out car windows"
Post Wed Sep 16, 2009 8:46 pm
Or more important to many of us, those Sport Scout replacements?
Hell, I need both.
(Wouldn't it make most sense to start with 13 fin castings? Its easier to take them off than to put them on. And frankly, even the '74"s would benefit!)
...Cotten
37ULH
Post Wed Sep 16, 2009 10:49 pm
I'm waiting for the 750 OHV kit.
fhsmith1
Post Sat Sep 19, 2009 10:38 am
Charlie Hadayia
A new and improved oil supply pump would be most excellent also!
F
hdrl1935
Post Thu Sep 24, 2009 11:11 am
37ULH wrote:I'm waiting for the 750 OHV kit.
+1
Or WR cylinders, heads and tappet guides. :roll:
MOLDTHREAD
Post Thu Sep 24, 2009 12:14 pm
I have lots of parts available for the WR!
Tappet guides
Roller cams with 10 different KR profiles
High lift single valve springs with rates equivalent to the dual KR springs
Valve spring covers
Peek a Boo timing cover
This spring I will have WR heads with KR style combustion chambers
WR cylinders are on the drawing board
Bruce
http://www.enfieldracing.com
Bruce Argetsinger
AHRMA Dirt Track # 67J
Users browsing this forum: FHP-Eric and 1 guest
