Milling crankcase deck surface – How much?
helsingborg
Post Sun Oct 19, 2008 7:07 pm
How much metal can be cut off from a stock UL crankcase deck surface without having a major manifold alignment problem. I’m trying to set the squish at 0.045-0.05 but I don’t want to mill the top of the cylinders, because both cylinders had already been nicely relieved and polished. Any suggestions?
Post Sun Oct 19, 2008 9:45 pm
Re: Milling crankcase deck surface – How much?
Mill the base of the cylinders.
helsingborg
Post Mon Oct 20, 2008 9:50 am
Thanks for the reply. But my dilemma still remains unsolved. As far as I know, milling the base of the cylinder will also affect the manifold alignment in the same extent. In order to reach 0.045 squish I must cut off 0.05 (crankcase deck or cylinder base). If I do so, will I need a custom manifold?
Thanks.
Helsingborg.
Post Mon Oct 20, 2008 2:57 pm
No, most manifolds are slightly loose, and the relationship isn't linear.
At worst you just file the ends of the legs slightly.
helsingborg
Post Mon Oct 20, 2008 4:27 pm
Thanks Panic! and Chris!
Helsingborg. :mrgreen:
