Spark plug heat range.
I could use some input as to what spark plugs and heat range is being used out there on big twin flatties using the smaller 14mm plugs.I have a 1940 UL with aluminum high compression heads,black widow mid range cams,auto advance 45 servi car timer,and an adjustable main jet Bendix 38mm carburetor.The motor has approximately 350miles since built and the bore is 10 over.The plugs i am currently using are Champion RN12YC.Is this heat range too hot? I cant get any color on the plugs.I have checked for air leaks,found none.A local carburetor shop familiar with these carbs recently has drilled out the main jet twice and now I am just starting to see some "pink" coloring on both plugs .Any info would be appreciated.Thanks
Joe E
