Notice: Undefined index: x_cat in /var/www/vhosts/sscycle/instructions/instructionslist.php on line 119
New from S&S
S&S Cycle
S&S Cycle, Inc. Performance Motorcycle Parts for American V-Twins
Sheet Number Description
ytreye
ytreytreyer
51-1072
XL FW for 34-7800 Rods
106-3124
X-Wedge® Rubbermount (XW-R)Transmission Case with Engine and Swing Arm Mount
106-1544
VFI Knock Sensor Kit for 2001-'07 Delphi® Style VFI Module (with USB)
51-1135
VFI Induction System (For use with S&S® Magneti Marelli® Style VFI Fuel Injection Systems 1995-2001)
51-1257
Valve Spring Kits for 1984-99 Big Twin, 1986-™03 Four-Cam, and 1999-Up Big Twin Engines
51-1040
V2 Tappets
51-1099
V2 Cylinder Stud
51-1074
Two Throat Carb Manifold
51-1158
Twin Cam®, SSW+ Head Breathing Groove Change
51-1052
Twin Cam® Rocker Cover Assemblies
51-1160
Twin Cam® Engine
51-1108
Twin Cam® Cylinder Head
51-1143
Twin Cam Reed Valve
51-1048
Twin Cam .510 Chain Drive Cam Hardware
51-1174
Torque Plates - 4-3/8" bore SSW+
51-1172
Torque Plates - 4-1/8" bore SSW+
51-1055
Torque Plate V2
510-0038
Throttle-by-Wire Throttle Hog Throttle Body
51-1009
Throttle shaft
51-1034
Template, late chamber
51-1033
Template, early chamber
106-0019
Technical Bulletin for MY06 Dual Bore Throttle Body
106-5388
Teardrop Installation Instructions for Late Model Fuel Injected Motorcycles
51-1175
TDC Stop
106-2468
TÜV Documentation, S&S® Super E Carburetor Kits
106-2469
TÜV Approved Super E Carburetor Kits
51-1165
Tag, SSW+ Breather Hose Information
51-1256
T124V Engine VFI™ Installation for 19951/2-1998 Chassis
106-4500
T111 Engine Assembly
51-1060
Super Stock® Cylinder Heads for 1966–'84 Shovelhead Models
51-1206
Super Stock Ignition
51-1228
Super E Carb on '04/'05 XL
51-1006
Super B Carb
51-1029
Stroker Kit Sportster®
106-5893
Standard and Easy Start Gear Drive Cams for Harley-Davidson® Twin Cam 88® Engines 1999-2006 Big Twin, except 2006 Dyna® models
106-6415
Standard and Easy Start Chain Drive Camshafts for Harley-Davidson® Twin Cam 88® Engines 1999-2006 Big Twin, except 2006 Dyna® models
51-1205
Spring kit Victory®
51-1027
Spring Kit Pan & Shovelhead Engines .550 Lift
51-1024
Spring Kit High Performance V2-Style
51-1023
Spring Kit BT & XL V2 Engines
51-1231
SPO Quiet Baffle (PN 55-6023)
51-1056
Speedometer Calibrator
51-1140
Slip-on Mufflers
51-1030
Sidwinder© Sportster©
51-1116
Sidewinder®; Twin Cam
51-1246
Shift Collar Replacement for S&S Transmission
51-1084
Shaft and Bearing Fit
51-1086
SH Valve Clearance
51-1180
Service Bulletin TC HLT2
51-1217
Service Bulletin Oil Seepage with 50-8063-S
510-0011
Serial Delphi VFI and ProTune II Software
106-0883
Secondary Drive Belt Handling and Installation
510-0100
S&S® Universal EFI Wiring Harness For Delphi® Style Modules
106-2738
S&S® T124 CLVFI Engine
106-5058
S&S® Super Stock® and Special Application Crankcases for 1936-'99 Big Twin Engines
510-0057
S&S® Super E and G Stealth Air Cleaner Kit for 1993–2006 Big Twins
510-0056
S&S® Stealth Air Cleaner Kit for 1993 and Up Stock CV Carburetor and 2001 and Up Stock Delphi EFI
106-6067
S&S® Standard and Easy Start Gear Drive Cams for 2007-Up BT and 2006-Up Harley-Davidson® Dyna®
106-5175
S&S® Roller Cam Kits (106-5282 & 106-5283) For 2008-Up Polaris® Ranger RZR® and RZRs®
51-1028
S&S® Pistons
51-1136
S&S® IST® Ignition System For All 1999-2003 Carbureted Harley-Davidson® Twin Cam 88® Engines
51-1153
S&S® IST Ignition System for 2004-Up Harley-Davidson® Models (51-1136 Supplement)
51-1155
S&S® Ignition System for 1984-’99 4 1⁄8" Bore Big Twin Engines
106-0894
S&S® EZFI™
510-0198
S&S® Camshafts for 1986-2013 Harley-Davidson® Sportster® Models
51-1051
S&S® Billet Rocker Cover Assemblies for Harley-Davidson® Evolution® engines
510-0084
S&S® B2 Cylinder Head Exhaust Flange Mounting Kit for S&S B2 Cylinder Heads Utilizing Stock or 2" OD Exhaust Systems
51-1062
S&S® Air Cleaners for Stock Harley-Davidson® Carburetors,1994-up Carbureted Buell® Models and all 1999-up Single Runner Fuel Injected Models
510-0087
S&S® 1200cc Piston and Cylinder Kits for Harley-Davidson® 883cc and 1200cc Sportster® Models
106-5986
S&S® 106" Big Bore Kit for 2007-Up BT & 97" Big Bore Kit for 1999-'06 BT (3.927" Bore Cylinders & Pistons)
106-3737
S&S®; Teardrop Air Cleaner Kit PN 106-3738 Installation Instructions for 2006-2008 Kawasaki® Vulcan® 900 Motorcycles
51-1071
S&S® Valve Clearance
106-4897
S&S® V113 TUV Approved Engine for 1984-�99 Big Twin
106-3992
S&S® V-Series California Engine Owner's Manual
106-0406
S&S® Torque Plate Kit for4 1/8" Bore Stock Pattern Cylinders for 1999-Up Big Twin Engines
106-1777
S&S® Torque Plate Kit for 4 1/8" & 4 1/4" Bore X-Wedge™ Cylinders
106-0503
S&S® Teardrop Installation Instructions for Late Model Motorcycles
106-3327
S&S® Teardrop Air Cleaner Kit Installation Instructions for 2002-Up Honda® VTX® 1800 Motorcycles
51-1002
S&S® TÜV Engine Owner’s Manual
51-1253
S&S® T124E TÜV Certified Engine
51-1213
S&S® T124 TÜV Certified Engine
106-2640
S&S® T124 CLEFI TUV Certification 2002-2006 Big Twin
106-2707
S&S® Sealed Air Cleaner
51-1161
S&S® Oil Pump for T-Series Engines & Harley-Davidson® Twin Cam 88® Engines
106-4426
S&S® Oil Filter Mount for S&S® Alternator/Generator, KN-Series, P-Series, SH-Series, 1986-'90 Harley-Davidson® Sportster® models, S&S® Superstock® and Special Application Crankcases for Sportster® and Buell® Models
106-5164
S&S® Intake Kit, PN 106-106-5012 For 2008-Up Polaris® Ranger RZR® and RZRs®
51-1219
S&S® Inner Primary Bearing Race Installation Tool PN 56-5145
51-1238
S&S® Gear Drive Cam Display
106-3162
S&S® Freedom® Performance Tuner for 2008-Up Victory® Motorcycles
106-4387
S&S® EZFITM on 2008-'09 Touring Models
106-3933
S&S® EZFI™-C
106-5033
S&S® Exhaust System, PN106-5013 For 2008 - Up Polaris® Ranger RZR® and RZRs®
51-1247
S&S® Clutch Removal and Inner Primary Bearing Race Removal Tool PN 56-5141
106-4374
S&S® Chain Drive Cams for 2007-Up BT and 2006-Up Harley-Davidson® Dyna®
106-3756
S&S® California X-WedgeTM Engine Owner's Manual
51-1241
S&S® Billet Primary Cover for1989-'06 Harley-Davidson© Softail®; and 1991-'05 Dyna® Models with Forward and Mid Controls
51-1220
S&S® Billet Primary Cover for VIctory® Motoryclces PN 47-0109
51-1240
S&S® Billet Oil Filter Mount with Oil Cooler Machining PN 31-4105
106-5394
S&S® Air Cleaner Kit PN 106-5131 for Victory® Motorcycles
106-5395
S&S® Air Cleaner Kit PN 106-5130 for Victory® Freedom® Engines
106-4616
S&S® Air Cleaner Installation Instructions for 1995-2001 Big Twins with Magneti Marelli® EFI
106-2026
S&S® 49-State EPA Certified Engine Owner's Manual
106-3354
S&S® 49-State Certified X-Wedge® Engine Owner's Manual
51-1260
S&S® 49 State EPA Certified Engine Owner's Manual
51-1212
S&S® 124 TUV CERTIFIED ENGINE
51-1211
S&S® 113 TÜV CERTIFIED ENGINE
51-1239
S&S&® Single Bore Induction System
106-3626
S&S Variable Pressure Plate Clutch Kit PN 106-2843 for Victory® Motorcycles
510-0009
S&S USB Magneti Marelli® Style VFI (Variable Fuel Injection) Module and ProTune II Software
106-2303
S&S Teardrop Installation Instructions for 2008-Up Touring Motorcycles
106-5803
S&S Teardrop Air Cleaner Kit for 2010-Up Honda® Fury™ 1300 Motorcycles
51-1230
S&S Super Stock® Ignition System Diagnostic Cable Operation Instruction
510-0058
S&S Super E and G Stealth Air Cleaner Kit for 1991–2003 Harley-Davidson® Sportster® Models
51-1196
S&S Super D Gasoline Carburetor Installation Instructions
510-0055
S&S Stealth Air Cleaner Kit for 2008 and Up Throttle-by-Wire Motorcycles
510-0054
S&S Stealth Air Cleaner Kit for 1991 and Up Harley-Davidson® Sportster® with Stock CV Carburetor and Stock EFI System
106-5912
S&S Standard & Easy Start Chain Drive Cams for 2007-Up Big Twin and 2006-Up Harley-Davidson® Dyna®
510-0003
S&S Shovelhead Head Bolt
106-4920
S&S Replacement Engine Owner's Manual
510-0085
S&S Power Tune Sport Exhaust System for 2004 and later Harley-Davidson® Sportster® Models (S&S PN 550-0230 and 550-0231)
510-0005
S&S Piston Rings
106-3982
S&S Easy Start Camshafts for X-Wedge® Engines
106-1330
S&S Billet Air Cleaner Kit PN 106-1319 for Victory® Motorcycles
51-1204
S&S Air Cleaner Kit 41-0021 for Victory® Freedom® Engines
510-0059
S&S Air Cleaner Covers
51-1210
S&S 96 TÜV CERTIFIED ENGINE
510-0060
S&S 1" Taller Hi Flow Air Filter Kit
51-1112
Rocker cover wrench set
51-1092
Rocker Cover Gaskets
51-1073
Rocker Cover Clearance
51-1193
Rocker Boxes for 1966-’84 Big Twin
51-1081
Rocker Box Hardware
106-4353
Rocker Arms and Rocker Shafts for 1936-'47 OHV VT and KN-Series Flathead Power®
51-1267
Rocker Arm Rebuild Kit for 1966-1984 Big Twin Engines
51-1142
51-1197
Replacement Cylinder Head Kit for '84-Up Evo® BT/XL
51-1012a
Replaceable Main Air Bleed for all S&S® Super "E" and "G" Carburetors
510-0083
Race Tour Mufflers - End Cap Installation
51-1195
Quickee Pushrod
51-1057
Pushrod Kit Twin Cam®
51-1035
Pushrod Kit
51-1200
Pro Stock Parts Manual
51-1162
Pro Stock Camshafts
510-0019
Power Tune Duals For Touring Models 2009-Up (PN 550-0004 and 550-0143)
510-0015
Power Tune Dual Instructions
51-1097
Pistons 3500/3700
51-1021
Pinion Shaft Big Twin
510-0082
Packing Instructions for #50-9578 S&S Engine Shipping Crate
51-1129
Packing Harley-Davidson® Twin Cam 88B® Engine in S&S® Shipping Crate 50-9589
51-1128
Packing Harley-Davidson® Twin Cam 88® Engine in S&S® Shipping Crate 50-9587
510-0199
Outerwear Pre-Filter for Stealth AC Kits
51-1077
OP Cover Fittings
510-0039
Oil Supply Line Installation Kit
106-4458
Oil Return Lines With S&S KN-Series Tins
106-6156
Oil Pump for TSeries Engines
51-1085
Oil Pump BT
6250
Oil Pump Big Twin
TB-2
Oil Carry-Over Technical Bulletin
51-1100
Oil Carry Over
51-1075
OEM Case Modification Outside Oiler Pan
106-3810
Notice of Requirements and Records
106-3811
Notice of Procedure to Obtain Engine MSO
51-1169
New style shovelhead base nuts
51-1095
New Air Filter 17-0376
51-1103
Modifications of 3500 & 3700 Series Pistons
51-1007
MGL Carb
51-1065
Manual Compression Release
51-1170
Manifold Measuring Tool
51-1049
Long Block Assembly Big Twin
51-1090
Long Block Service Specs
106-6005
Lloydz Motorworkz Billet Air Cleaner Kit for Victory® Motorcycles
510-0007
Lloydz Motorworkz 107" and 114" Big Bore Kit for Victory® Motorcycles
51-1156
IST Ignition System for 1984-1999 Big Twin and Custom Applications
51-1167
IST Ignition - Evo w/ Toothed Flywheel
55-1542
IST Custom Bike Wiring Harness
510-0026
Installing Spring Kits on 7mm Valve Stems
51-1003
Installation Instructions: TÜV Engine Assembly
51-1514
Installation Instructions: Frame Lock®
51-1262
Installation Instructions for Single Bore Tuned Induction System
106-4891
Installation Instructions for S&S® Single Bore Tuned Induction Kit for 2008-Up Touring Models with Electronic Throttle Control
51-1270
Installation Instructions for S&S® Single Bore Induction System
106-1670
Installation Instructions for S&S® In-Tank Fuel Pump Instructions
106-3161
Installation Instructions for S&S® Freedom® Performance Tuner for 2003-'07 Victory® Motorcycles
51-1145
Installation Instructions for S&S VFI Module and ProTune II Software
51-1258
Installation Instructions for G-Extreme Dual Carb Kit
51-1254
Installation Instructions for 79cc Heads
106-6045
Installation Instructions and Adjustment Procedures for 1936-'84 BT & 1957-'85 XL S&S® Pushrod Kits
51-1012
Installation and Jetting Instructions for S&S Super E and G Series "Shorty" Carburetors
51-1233
51-1178
Ignition Coil
51-1242
Hydraulic Side Cover Kit
51-1126
HVHP Oil Pump Big Twin
51-1039
HL2T kit
106-5860
High Performance Clutch
51-1164
High flow air cleaner element and extensions
51-1042
Head Kit Evo Big Twin & Sportster®
106-2955
Head Gasket Tightening Torque Specifications
51-1016
Head Gasket Stock Bore V2 Cylinder
51-1017
Head Gasket Copper Shovelhead-Style
51-1044
Head Bolts Evolution® Style Cylinder
51-1079
Head Bolt Torque Specs
51-1087
Head Bolt Tightening
106-6081
Hardware Usage Notice —Generator Gearcover
51-1080
H-D® Alternator
51-1506
Guardian IST ignition software
51-1018
General Instructions for All Flywheel Installations and Instructions for 3 7/16" - 3 1/2" Bore Big Twin Stroker Kit 1936-1999
51-1032
Gearcover Kits for Big Twin Crankcases
51-1232
Gear Set Cassette Transmission
51-1234
Gear Drive Cams for 2006- Up H-D® Twin Cam 88®Engines
51-1047
Gear Drive Cams for 1999-2006 (Except 2006 Dyna®) H-D® Twin Cam 88® Engines
51-1008
GAL/GBL Carb Instructions
510-0020
Fuel System Upgrade Kit with Magneti Marelli® Style VFI Module and Single Bore Throttle Body
106-3149
TB-4
Four-Inch Bore Piston Weights Technical Bulletin
106-6072
Forged Pistons
51-1045
Foam Air Filter Elements
51-1020
Flywheel General
51-1019
Flywheel Fully Assembled Sets
51-1061
External Oil Returns Shovel Cylinders
106-3755
Emission-Related Installation Instructions for S&S® California X-WedgeTM Engines
106-2027
Emission-Related Installation Instructions for S&S® 49-State EPA Certified Engines
106-3353
Emission-Related Installation Instructions for S&S® 49-State Certified X-Wedge® Engines
106-4921
Emission-Related Installation Instructions for S&S Replacement Engines
51-1271
Emission Related Installation Instructions for S&S® 49_State EPA Certified Engines
51-1115
Electric Compression Release
51-1094
Dynamic Balancing
106-6399
Dual Valve Spring Kits for 1984-12 BT and 1986-'12 Four-Cam Engines
51-1151
Dual Bore Induction System (For use with S&S® Delphi® Style VFI Fuel Injection Systems 2002-up)
51-1064
Dowel Cylinder Alignment-Oil Drain
51-1054
Die-Cast Rocker Cover for Harley-Davidson® Twin Cam 88® & Evolution® Engines
51-1038
Degree Wheel
51-1043
Cylinders Stock Bore Shovelhead
51-1177
CV Carb Jet Kits
106-3645
Custom Connector Kit for the S&S® EFI Wire Harness
51-1141
Cruise control bracket for VFI induction
51-1119
Cruise control
51-1050
Crankcase S&S XL SA 3.625
51-1255
Crankcase for Harley-Davidson® Twin Cam 88® Engines
51-1107
Crankcase Breather Stud Assembly
51-1063
Crankcase Big Twin Super Stock
51-1159
Connector Plug
51-1025
Connecting Rod Big Twin & Sportster®
51-1198
Complete Transmission
51-1070
Coated Head Gaskets
510-0049
CNC Ported Heads for T-Series Engines Clearancing Instructions Part Number 106-5880
106-0048
Closed Loop Fuel Injection for Magneti Marelli® Style S&S® Replacement Module (Supplement to Instruction 51-1145)
51-1203
TB-3
Change in S & S© Breather Gears Technical Bulletin
51-1076
Caution - Polishing, Plating, etc.
51-1058
Case S&S® 5-Speed Transmission for 1986-1999 Softails®
51-1059
Case S&S® Transmission, 4 - 5 Speed Conversion
51-1013
Carburetor Super E & G Twin Cam Engines
51-1010
Carburetor 2-Throat
51-1093
Carb Usage
51-1046
Camshaft Kits Twin Cam
51-1026
Camshaft Big Twin
106-3812
California Engine Agreement Statement
51-1091
Cable Guides
51-1036
Buret
51-1137
Buell front motor mount, billet
51-1014
BT Sidewinder 3-5/8" bore kits shvl, Evo.
51-1041
BT Billet Oil Pump
51-1194
Breather Reed Valve for 1993-1999 Big Twin
51-1101
Breather Gears
51-1096
Boring Plate Modification
51-1216
Billet Generator Timer for Super Stock Ingnition
510-0041
Billet Aluminum Rocker Arm Kit for X-Wedge® Engines
51-1166
Bearing & Seal Installation Tool
510-0010
Barometric Pressure Sensor Relocation Kit
51-1037
Balance Kit
51-1089
Bad Tappet Guides
51-1105
Assembly Instructions: Box Assembly #50-9581 S&S® Engine Shipping Crate
106-2031
Assembly Installation Instructions for S&S® EFI Wire Harness for Custom Frame Applications Using S&S® Fuel Injected Engines and Delphi® Style Modules
51-1069
Air Lock Prevention
51-1011
Air Cleaner Backplate for Super E & G Carburetor
51-1082
Adjusting Piston Gap
51-1088
Adjusting Lifters
106-6046
Adjustable Pushrods
510-0088
80" Replacement Pistons For Harley-Davidson® Evolution® Models
510-0071
510-0071 Universal Stealth Air Cleaner Kit for 1936–'92 Big Twin and 1957–'90 XL
510-0061
510-0061 S&S® Dual Valve Spring Kits for 1984-'12 Big Twin and 1986-'12 Four-Cam Engines (PN 90-2277 & 900-0420)
510-0042
510-0042 Flathead Power® Rocker Cover Gaskets (1948–’65) P/N 900-0339 (Set) 900-0329 (Individual)
510-0035
510-0035 S&S® Super Stock® C Ignition in Carbureted, 2004–2007 American Ironhorse® Motorcycles
510-0031
510-0031 Hardware Verification Notice—Thread Size
510-0030
510-0030 Breather Reed Valve Notice
51-1261
51-1261 Emission-Related Installation Instructions for S&S® 49-State EPA Certified Engines
51-1190
51-1190 Notice -Plugs
51-1053
50 State Legal Air Filter
51-1106
50 State Air Filter
106-4736
50 State Air Cleaner Kit 106-4735 for Victory® Freedom® Engines
51-1124
4-1-8" SSW+ Long Block Assembly Big Twin
51-1083
4" Head Bolt
51-1004
4" Bore Long Block TÜV Automotive Certificates
51-1102
4" Bore Piston Weights
51-1005
3 5/8" Bore Long Block TÜV Automotive Certificates
106-2877
2009-Up S&S 495 Camshafts for Victory® Motorcycles
510-0029
2009-2011 Harley-Davidson®Tri-Glide® Header Adapter
106-2932
19951/2 - 1998 EFI Stock Crank Position Sensor Installation
51-1201
124ci V-Series TÜV Specifications
106-2873
51-1114
106" Stroker Kit for Twin Cam
51-1207
106" Stroker Hot Set Up Kit® For Victory® Freedom® Engines
106-1596
103" Pistons
510-0027
.650 Lift Conical Valve Spring Kit
51-1022
.590" Lift Valve Spring Kits #90-2060 and #90-2063 for 1948–1984 Big Twin Engines
510-0048
.585" and .650" Sidewinder® Springs for X-Wedge®
51-1215
.495" Lift Camshaft for Victory®
97 inch big bore kit
High Tech Diagnosis with Guardian System
Slip-On Performance Exhaust Systems
High Flow Air Filter Kit
footer image1
dynojet website
viola v-twin website
Copyright © 2013 S&S Cycle, Inc. Viola Wisconsin
powered by invisizon
flathead power motorcycle vintage parts
Crane Cams
footer image
    S&S Cycle facebook page S&S X-Wedge facebook page S&S Cycle youtube videos
Flathead Power Fourms
S&S Polaris RZR Forum
S&S Honda Fury Forums
RSS feed S&S News and Events
Visit Us On Twitter
